Penna usb sky e MyTube su BH 1.6
Ecco il dmesg:
usbcore: registered new driver zaurus
TCP bic registered
NET: Registered protocol family 1
usb 1-2.7: new high speed USB device using brcm-ehci and address 5
usb 1-2.7: configuration #1 chosen from 1 choice
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 140k freed
JFFS2 notice: (20) check_node_data: wrong data CRC in data node at 0x0704d800: read 0x415e249d, calculated 0xe81fe46a.
JFFS2 notice: (20) read_dnode: node CRC failed on dnode at 0x52cffdc: read 0xffffffff, calculated 0x7b010b6
libata version 2.00 loaded.
brcm-pm: enabling power to SATA block
sata_svw 0000:01:00.0: version 4.0
ata1: SATA max UDMA/133 cmd 0xB0510000 ctl 0xB0510020 bmdma 0xB0510030 irq 42
ata2: SATA max UDMA/133 cmd 0xB0510100 ctl 0xB0510120 bmdma 0xB0510130 irq 42
scsi0 : sata_svw
Initializing USB Mass Storage driver...
scsi2 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 4
usb-storage: waiting for device to settle before scanning
scsi3 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 5
ata1: SATA link down (SStatus 4 SControl 300)
ATA: abnormal status 0x7F on port 0xb051001c
scsi1 : sata_svw
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl F0000)
ata2.00: ATA-7, max UDMA/133, 976773168 sectors: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA/133
  Vendor: ATA       Model: ST3500830AS       Rev: 3.AA
  Type:   Direct-Access                      ANSI SCSI revision: 05
SCSI device sda: 976773168 512-byte hdwr sectors (500108 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
 sda: sda1
sd 1:0:0:0: Attached scsi disk sda
sd 1:0:0:0: Attached scsi generic sg0 type 0
procmk_init
JFFS2 notice: (20) check_node_data: wrong data CRC in data node at 0x06867800: read 0x185dcd8b, calculated 0xa9788907.
dvb_bcm7335: module license 'Proprietary' taints kernel.
DVB: registering new adapter (bm750)
bcm7335: hotplug_callback():
Hotplug - status.connected 0
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
isa bounce pool size: 16 pages
  Vendor: ChipsBnk  Model: SD/MMCReader    [VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
  Rev: 4081
  Type:   Direct-Access                      ANSI SCSI revision: 02
SCSI device sdb: 1989632 512-byte hdwr sectors (1019 MB)
  Vendor: TSSTcorp  Model: CDDVDW SE-S084F   Rev: TS00
  Type:   CD-ROM                             ANSI SCSI revision: 00
scsi 3:0:0:0: Attached scsi generic sg1 type 5
sdb: Write Protect is off
[MPVR]: >> misc_pvr_init
sdb: Mode Sense: 0b 00 00 08
sdb: assuming drive cache: write through
usb-storage: device scan complete
 sdb: sdb1
sd 2:0:0:0: Attached scsi removable disk sdb
sd 2:0:0:0: Attached scsi generic sg2 type 0
input: dreambox remote control (native) as /class/input/input0
[LCD]: registered
[CI]:-BM750_PCB_2_1
[CI]: registered ci0
[CI]: registered ci1
[DFP]: registered dbox fp
[DFP]: bcm7335_i2c_write: Error 1114113
[DFP]: bcm7335_max_i2c_write: Error 1114113
[DFP]: Scart 4707 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 3:0:0:0: Attached scsi CD-ROM sr0
NTFS driver 2.1.27 [Flags: R/W MODULE].
ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x40000000 action 0x0
ata2.00: tag 0 cmd 0xef Emask 0x1 stat 0x51 err 0x4 (device error)
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0
kjournald starting.  Commit interval 5 seconds
EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
EXT3 FS on sda1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
EXT3 FS on sdb1, internal journal
dvb-usb: found a 'Avermedia Sky Digital Pen (A867)' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9035-01.fw'
dvb-usb: found a 'Avermedia Sky Digital Pen (A867)' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (Avermedia Sky Digital Pen (A867))
af9033: firmware version: LINK:11.15.10.0 OFDM:5.48.10.0
DVB: registering adapter 1 frontend 0 (Afatech AF9033 DVB-T)...
mxl5007t 0-00c0: creating new instance
mxl5007t_get_chip_id: unknown rev (3f)
mxl5007t_get_chip_id: MxL5007T detected @ 0-00c0
dvb-usb: Avermedia Sky Digital Pen (A867) successfully initialized and connected.
usbcore: registered new driver dvb_usb_af9035
af9035: command:03 failed:2
mxl5007t_write_reg: 475: failed!
mxl5007t_init: error -140 on line 702
DVB: registering adapter 0 frontend 0 (Afatech AF9033 DVB-T)...
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7335 platform
[CI]:Opening A GPIO's for 7335 platform....done
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:Opening B GPIO's for 7335 platform
[CI]:Opening B GPIO's for 7335 platform....done
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[CI]:NEXUS_Remux_Start
[CI]:>>close_mpod tuner:0
[CI]:remux stop
[CI]:get_remux_startcnt() count : 1
[CI]:>>close_mpod tuner:1
[CI]:remux stop
[CI]:get_remux_startcnt() count : 0
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -2017690144
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -200, right volume -200
mxl5007t_soft_reset: 523: failed!
mxl5007t_tuner_init: error -140 on line 536
mxl5007t_set_params: error -140 on line 671
Se ti serve anche il cat /proc/bus/usb/devices l'ho postato un prima..
Ecco il dmesg:
TCP bic registered
scsi0 : sata_svw
scsi1 : sata_svw
 sda: sda1
procmk_init
  Rev: 4081
 sdb: sdb1
[LCD]: registered
[CI]:-BM750_PCB_2_1
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:remux stop
Va benissimo questo.
Gli errori sono i medesimi che ho riscontrato io con la pennetta in uno stato incoerente e che nemmeno un reboot hanno risolto visto che ho dovuto scollegare la pennetta dal box per farla rinsavire.
Se non ho visto male, in fase di reboot il led della tua penna dovrebbe essere acceso perennemente.... (potrei sbalgiarmi... ma ho questa sensazione).
Non ci ho fatto caso, visto che la pennetta è nascosta abbastanza bene.. :oops:
Se ti occorre saperlo reinstallo i driver da pannello (per ora sto andanto con quelli "patchati" a mano..) e faccio la prova..
Prova con i driver da pannello.
In fase di reboot del box, la luce DEVE spegnersi per poi riaccendersi in caso di init positivo.
Se rimane perennemente accesa ci sono dei problemi :) e va seguita la procedura che avevo indicato (che comunque vale per la stragrande maggioranza dei devices DVB USB in caso di problemi).
ecco il mio se può essere utile dopo che ho disabilitato la pennetta scaricato i driver da pannello abilitato e riavviato
EXT3-fs: recovery complete.
CIFS VFS: Error connecting to IPv4 socket. Aborting operation
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
ata2: EH complete
SCSI device sda: 156301488 512-byte hdwr sectors (80026 MB)
Adding 65528k swap on /mnt/usb/swapfile. Priority:-1 extents:21 across:81464k
oad a firmware
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:remux stop
[AUD]: AUDIO_SET_MIXER -2019025440
[AUD]: AUDIO_SET_MIXER : amixl 4, amixr 4
[AUD]: AUDIO_SET_MIXER : next left volume -485, right volume -485
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: bcm7335->audio_dec_ss.codec 1
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 2 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0a13ccc
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[SC]: !!!unknown cmd 0x5407
[VID]: VIDEO_STOP 1 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
FE tune
[VID]: VIDEO_GET_SIZE src w: 720 h:576 display w:720 h:576
[VID]: VIDEO_GET_SIZE aspect: 1 3
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
FE tune
[VID]: VIDEO_GET_SIZE src w: 0 h:0 display w:0 h:0
[VID]: VIDEO_GET_SIZE aspect: 1 0
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 proc_get_ac3 0 bcm7335->audio_passthrough_spdif : 0
[AUD]: bcm7335->audio_dec_ss.codec 7
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_PLAY 1 5 2
[AUD]: AUDIO_STOP 1
FE tune
[AUD]: AUDIO_STOP 1
FE tune
root@bm750:~#
Infatti.:D
Quello che non capisco è perchè qualcuno ha problemi.
Saranno davvero diverse le pennette??
Una cosa la devo dire .
Ho voluto mettere per prova un backup BH in multiboot e la stessa pennetta anche andando a pescare dal pannello non veniva riconosciuta. Facendo ripartire l'immagine in flash e senza fare nulla la A867 funzionava perfettamente
Infatti.:D
Le pennette sono identiche: ho verificato i dmesg postati da te e dall'utente con problemi.
Nel caso del multiboot, non usandolo non ho fatto dei tests approfonditi in merito.
Non potrebbero esserci delle differenze anche a livello di hw (tra duo e solo)?? Questo perchè con la mia a867 con il solo non c'è stato verso di farla funzionare! Se serve qualche output sono ovviamente a disposizione.
Servirebbe il dmesg dopo un riavvio del tuo box.
Eccolo: immagine 1.6, driver a867 da pannello e penna sempre inserita.
dmesg
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 128kB, 8-way, linesize 128 bytes.
SCM configuration: 00fac688 41d4d617 00f07100 8fff0d00 81ff0100 0fff0fff
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
timer irq 100
PID hash table entries: 2048 (order: 11, 8192 bytes)
Found MIPS counter frequency: 167 Mhz
Using 166.501 MHz high precision timer.
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 109056k/262144k available (2474k kernel code, 152948k reserved, 501k data, 124k init, 0k highmem)
Calibrating delay loop... 220.67 BogoMIPS (lpj=110336)
Mount-cache hash table entries: 512
Checking for 'wait' instruction...  available.
NET: Registered protocol family 16
PCI->SDRAM window size: 512MB
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 8192 bind 4096)
TCP reno registered
brcm-pm: disabling power to USB block
brcm-pm: disabling power to ENET block
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 22) is a 16550A
loop: loaded (max 8 devices)
brcm-pm: enabling power to ENET block
Broadcom BCM7325 P20 Ethernet Network Device v2.0 May  3 2011 15:52:35
Config Internal PHY Through MDIO: 100 MB Full-Duplex (auto-neg)
blackhole initialised
Broadcom STB NAND controller (BrcmNand Controller)
i=0, CS[0] = 0
NAND_CS_NAND_XOR=00000001
brcmnand_probe: CS0: dev_id=00000000
After: NandSelect=00000101, nandConfig=55042200
DevId 00000000 may not be supported.  Will use config info
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
timing1 not adjusted: 4232222d
timing2 not adjusted: 00000d94
BrcmNAND mfg 0 0 UNSUPPORTED NAND CHIP 128MB
Found NAND: ACC=d3000000, cfg=55042200, flashId=00000000, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0200 128MB @00000000
Found NAND chip on Chip Select 0, chipSize=128MB, usable size=128MB, base=0x
brcmnand_scan: B4 nand_select = 00000101
brcmnand_scan: After nand_select = 00000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.0 NAND flash size 128MB @18000000
mtd->oobsize=64, mtd->eccOobSize=16
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table found at page 65472, version 0xFF
Bad block table found at page 65408, version 0xFF
nand_read_bbt: Bad block at 0x00160000
nand_read_bbt: Bad block at 0x05380000
nand_read_bbt: Bad block at 0x07040000
brcmnandCET: Status -> Deferred
        numchips=1, size=8000000
Creating 7 MTD partitions on "bcm7xxx-nand.0":
0x0000000000000000-0x0000000007400000 : "rootfs"
0x0000000007400000-0x0000000007800000 : "kernel"
0x0000000007800000-0x0000000007c00000 : "boot"
0x0000000007c00000-0x0000000007d00000 : "cfe"
0x0000000007d00000-0x0000000007d80000 : "mac"
0x0000000007d80000-0x0000000007e00000 : "env"
0x0000000007e00000-0x0000000007f00000 : "nvm"
usbmon: debugfs is not available
ehci_hcd_brcm_init: Initializing 2 EHCI controller(s)
brcm-pm: enabling power to USB block
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-0)
drivers/usb/host/ehci-brcm.c: starting brcm EHCI USB Controller
 - USB h/w setup mode <B>
 - USB power enable set for active HIGH mode
brcm-ehci brcm-ehci.0: BRCM EHCI
brcm-ehci brcm-ehci.0: new USB bus registered, assigned bus number 1
brcm-ehci brcm-ehci.0: irq 62, io mem 0x10480300
brcm-ehci brcm-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
10 Dec 2004 USB 2.0 'Enhanced' Host Controller (EHCI) Driver (EHCI-brcm-1)
brcm-ehci-1 brcm-ehci-1.1: BRCM EHCI
brcm-ehci-1 brcm-ehci-1.1: new USB bus registered, assigned bus number 2
brcm-ehci-1 brcm-ehci-1.1: irq 63, io mem 0x10480500
brcm-ehci-1 brcm-ehci-1.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd_brcm_init: Initializing 2 OHCI controller(s)
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-0)
drivers/usb/host/ohci-brcm.c: starting brcm OHCI USB Controller
 - Resetting at b0480408
 brcm_start_hc
brcm-ohci-0 brcm-ohci-0.0: BRCM OHCI
brcm-ohci-0 brcm-ohci-0.0: new USB bus registered, assigned bus number 3
brcm-ohci-0 brcm-ohci-0.0: irq 64, io mem 0x10480400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
usb 1-1: new high speed USB device using brcm-ehci and address 2
2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (OHCI-brcm-1)
 - Resetting at b0480608
 brcm_start_hc
brcm-ohci-1 brcm-ohci-1.1: BRCM OHCI
brcm-ohci-1 brcm-ohci-1.1: new USB bus registered, assigned bus number 4
brcm-ohci-1 brcm-ohci-1.1: irq 59, io mem 0x10480600
usb 1-1: configuration #1 chosen from 1 choice
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usb 2-1: new high speed USB device using brcm-ehci-1 and address 2
usb 2-1: configuration #1 chosen from 1 choice
usbcore: registered new driver pegasus
drivers/usb/net/rtl8150.c: rtl8150 based usb-ethernet driver v0.6.2 (2004/08/27)
usbcore: registered new driver rtl8150
usbcore: registered new driver asix
usbcore: registered new driver cdc_ether
usbcore: registered new driver net1080
TCP bic registered
Empty flash at 0x02d616a0 ends at 0x02d61800
Freeing unused kernel memory: 124k freed
scsi0 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 2
procmk_init
dvb_bcm7325: module license 'Proprietary' taints kernel.
DVB: registering new adapter (vusolo)
[LCD]: registered
[LCD]:power led off
[LCD]:bm730_dbox_lcd_write_data
[LCD]:vfd reply success
[DFP]:max9597_Shutdown data = 0x80
[LCD]:bm730_dbox_lcd_write_read_data len: 8
[LCD]:rtc data received 4
  Vendor: TDKMedia  Model: Trans-It Drive    Rev: PMAP
  Type:   Direct-Access                      ANSI SCSI revision: 00
SCSI device sda: 7809024 512-byte hdwr sectors (3998 MB)
sda: Mode Sense: 23 00 00 00
sda: assuming drive cache: write through
 sda: sda1
sd 0:0:0:0: Attached scsi removable disk sda
sd 0:0:0:0: Attached scsi generic sg0 type 0
Adding 65528k swap on /mnt/usb/swapfile.  Priority:-1 extents:18 across:65628k
[LCD]:dbox_lcd_open
[LCD]:dbox_lcd_ioctl cmd : 4117
[LCD]: unknown cmd 0x1015
[DFP]:dbox_fp_open
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7325 platform
[CI]:Opening A GPIO's for 7325 platform....done
[CI]:Opening B GPIO's for 7325 platform
[CI]:Opening B GPIO's for 7325 platform....done
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:get_remux_startcnt count : 0
[CI]:remux stop
[DFP]:dbox_fp_open
[DFP]:dbox_fp_ioctl cmd : 0
[DFP]:dbox_fp_ioctl cmd : 256
[DFP]:dbox_fp_release
[DFP]:scart_select_tvvideotype TV = 0
[DFP]:max9597_fast_blanking data = 0x0
[DFP]:max9597_enable_output data = 0x6
[DFP]:scart_select_screentype aRatio = 1
[DFP]:max9597_slow_blanking data = 0x3
[DFP]:scart_select_tvout aTVOutType = 2
[AUD]: AUDIO_SET_MIXER -2084422136
[DFP]:dbox_fp_ioctl cmd : 7
[DFP]:dbox_fp_ioctl FP_IOCTL_GET_VCR
FE tune
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0a7de2c
Unica soluzione che ho trovato è sfilare la pennetta, riavviare il box e prima che appaia il logo BH di "Booting..." reinserirla.
Questo perchè il tuner ha dati sporchi/incoerenti in memoria e decide di impallarsi.
Questo giro del fumo (comune purtroppo alla stragrande maggioranza delle AverMedia possono essere soggette) mi ha fatto riprendere a visionare il DVB-T.
Test di sintonia e scansione effettuati entrambi con esito positivo.
Ho eseguito questa procedura ed adesso funziona tutto correttamente; prima non andava.
Ho fatto la prova (driver ufficiali): effettivamente in fase di reboot la luce si spegne e si riaccende durante il loading, ma non funziona lo stesso..
Da quello che ho capito, hai sempre lasciata inserita la pennetta ad ogni operazione, giusto?
No! Per fare la prova, partendo dai driver "patchati" funzionanti, la sequenza di operazioni compiute è stata:
  • disabilitare driver dal menu dei tuner e conseguente riavvio
  • installazione dei driver da pannello, abilitazione e alla richiesta di riavvio scelto no
  • spegnimento hardware del decoder e rimozione della pennetta
  • accensione: dopo circa 5 secondi, prima della prima schermata di boot, inserimento della pennetta
  • ..contatazione che non funziona..
Sbaglio qualcosa?
Sbaglio qualcosa?
Non credo dipenda da questo ma la procedura eseguita da me è leggermente diversa:
- con pennetta inserita ho installato i driver e l'ho attivata
- su richiesta di riavvio ho riavviato (con penna inserita)
- dopo il riavvio ho provato i canali ma non andavano
- ho fatto uno shutdown del decoder
- ho spento da dietro
- ho staccato la pennetta
- ho acceso il decoder da dietro
- ho inserito la pennetta poco prima del logo VU+
- ho provato i canali e questa volta si vedevano
Nuovi test. Provato con altre due pennette A867 e tutto fiunge perfettamente con i driver sul server BH.
Con la terza, invece, non c'è verso di farla funzionare.
Questo è il log dmesg della pennetta A867 non funzionante:
af9035: command:03 failed:4
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:remux stop
UDF-fs: No VRS found
[AUD]: AUDIO_SET_MIXER -2050359840
root@bm750:~#
Scusate: questa è la parte iniziale del log riferito alla pennetta
